Fiasco
Кабелов е одличен. Се конектира на вашата USB порта со USB портата на друг компјутер и се користи за трансфер на фајлови помеѓу компјутерите со прилично голема брзина. Трансферот е peer to peer file.
Features
Direct cable link of two PCs via the USB port
Plug and Play with hot plug
Over current protection
USB 2.0 transfer rates up to 480 Mbps (backwards compatible with USB 1.1 rates of up to 12 Mbps)
Share files and transfer data conveniently
Bus powered
No external power source needed
Driverless design (executable program installed on a flash chip built into the cable)
Approximately 6 feet from plug to plug
Dimensions: 6x1.5x8.75 inches
from: http://store.worldstart.com/product.php?productid=2606
Features
Bus powered
