- Ја почнал/а темата
- #1
Taurus
Taurus's setup
- Processor & Cooler
- i5-2500K Quad 3.3GHz LGA 1155 6MB + Cooler Deepcool Gammaxx 200
- Motherboard
- Gigabyte Z68P-DS3
- Storage
- WD 1ТB SATA3 Caviar Black 7200rpm 64MB + SSD 2.5" Samsung 850 Evo 250GB
- PSU
- 460W Gigabyte Superb Real Power
- RAM
- 2x4GB DDR3 1866Mhz Kingston CL11 HyperX Genesis
- Video card
- Sapphire ATI PCX R9 270X 2GB GDDR5
- Case
- Gigabyte LUXO X140
- Mouse
- Zalman ZM-M300 Black
- Keyboard
- Sweex Illuminating
- Audio
- DeLux 2.1
- Monitor
- Dell UltraSharp U2311H 23" e-IPS
- OS
- Win 8.1
Имам проблем со лаптопот со мрежната. Кога ке го приклучам мрежниот кабел од АДСЛ-от ми јавува порака: This connection has limited or no connectivity
Пробав со ова:
If you are receiving this error, you should run the Microsoft patch (KB884020) for it. Follow the instructions below to do this. Alternatively, you can download a zip file with the patch, registry file, and instructions by clicking here.
1) Download the patch from Microsoft's site
2) Run the update to install it
3) Run this short Registry fix to complete the update. Type the following lines in Notepad and save the file as FixReg.reg on your desktop, then double click on it to install into your registry.
Windows Registry Editor Version 5.00
[HKEY_LOCAL_MACHINE\SYSTEM\CurrentControlSet\Services\IPSec]
"AssumeUDPEncapsulationContextOnSendRule"=dword:00000002
Ама ни ова не ми помогна.
Драјверите се иначе нови, а користам Win SP2.
Пробав со ова:
