Problem so forma
Дискусија во форумот 'Генерална дискусија' започната од Electronic, 16 Септември 2019.
  1. Electronic
    Electronic
    39
    28 Мај 2019
    Sakav da formatiram laptopot (ne e prv pat formatiran) naidov na ovoj problem :Windows cannot be installed to this disk. The selected disk is of the GPT partition style.
    Posle toa pobarav solution na google i go napraviv ova :
    Step 1 Press keys Shift + F10 when you see the "The selected disk is of the GPT partition style" error during system installation, which opens Command Prompt. If that does not work, please go back to the first screen of the installation and press Shift + F10.
    Step 2 Type diskpart in the command prompt and press Enter.
    Step 3 Type command list disk and press Enter, which lists all disks connected to your computer.
    Step 4 Type select disk # and press Enter. Replace # with the disk number representing the hard disk which is of GPT partition style.
    Step 5 Type clean and press Enter. This command deleted all partitions and data from the selected disk.
    Step 6 Type convert mbr and press Enter. This command convert disk to MBR format. You can exit Command Prompt when you see "DiskPart successfully converted selected disk to MBR format".
    Otkako go zavrsiv ova se restartira i mi pokaza crn ekran so poraka:
    reboot and select proper boot device or insert boot media in selected boot device and press a key
    Vo biosot se e podeseno kako treba
    1 boot e hdd no sepak ne go cita hdd
    Прикачени датотеки:
  2. Avid
    Avid
    4,617
    6,971
    21 Јануари 2009
    Па сега треба усбто да го ставиш како 1 boot
    Ако не го препознава usbto може треба нешо legacy да уклучиш таму у bios
    На Electronic му/ѝ се допаѓа ова.
  3. Electronic
    Electronic
    39
    28 Мај 2019
    Prvo e staveno usb pa 2 e hdd i 3 boot e cdroom. Isto pa ne cita
    Прикачени датотеки:
  4. Uber-
    Uber-
    158
    150
    23 Август 2017
    Занаетчија
    Од што инсталираш, диск или усб ?
  5. Electronic
    Electronic
    39
    28 Мај 2019
    Od usb, formatirav na drugarmi preska pc i vikav uspat i laptopo da formatiram. Usb treba da e ispravo botirano
  6. Uber-
    Uber-
    158
    150
    23 Август 2017
    Занаетчија
    Со што го правеше бутабилно усбто ?
  7. Electronic
    Electronic
    39
    28 Мај 2019
  8. Avid
    Avid
    4,617
    6,971
    21 Јануари 2009
    baraj legacy u bios
  9. it_boy
    it_boy
    495
    415
    9 Јули 2018
    кога ќе стигниш до Where do you want to install Windows? одбери го хард дискот и delete мани на сите партиции (се ќе биде избришано!!!) и кликни после на New и автоматски ќе креира партиции со мбр формат и пробмелот е решен
  10. Avid
    Avid
    4,617
    6,971
    21 Јануари 2009
    уше да сфатеше ти дека он веќе конвертираше у мбр
  11. Uber-
    Uber-
    158
    150
    23 Август 2017
    Занаетчија
    Грешката што ти ја дава значи дека твојот биос е сетиран само да бутира само на легаси биос мод али дискот - партиципацијата кај што пробуваш да го инсталираш виндовсот е сетиран на ГПТ. Пробај во биос да смениш од легаси во уефи и пробај да го инсталираш пак. Доколку таа опција ја немаш - тогаш најлесен начин ти е напрај го усб-то од ново али избери ГПТ место МБР во руфус.
  12. Avid
    Avid
    4,617
    6,971
    21 Јануари 2009
    да не имате пиено нешто?
  13. Electronic
    Electronic
    39
    28 Мај 2019
    Nemam nogu opcii u bioso mn e ednostaven
    Прикачени датотеки:
  14. Avid
    Avid
    4,617
    6,971
    21 Јануари 2009
    Кој модел ти е лаптопот?
  15. Electronic
    Electronic
    39
    28 Мај 2019
    Mislam deka ima smisla ova
  16. Electronic
    Electronic
    39
    28 Мај 2019
  17. Avid
    Avid
    4,617
    6,971
    21 Јануари 2009
    Има смисла да. Ти го направи дискот MBR (а беше ГПТ), сега треба да го направиш усб-то од ново али избери ГПТ место МБР во руфус. :D:D:D
    Последна промена: 16 Септември 2019
    bxxxn, Daniel86 и на farkizz им се допаѓа ова.
  18. Arabian
    Arabian
    643
    377
    5 ноември 2013
    А да дадеш на некој дечко 500че и мирна глава на сите?
    На olikomerc му/ѝ се допаѓа ова.
  19. Uber-
    Uber-
    158
    150
    23 Август 2017
    Занаетчија
    Откако го направи МБР, пак ти ја дава истата грешка при инсталација?
  20. Electronic
    Electronic
    39
    28 Мај 2019
    Ne e rabota za 500ce mislam deka e dobar problem so nogu retko moze da go resat, nekoj decko.. :D
  21. Electronic
    Electronic
    39
    28 Мај 2019
    Da sega diskot e fakticki MBR i usb e MBR verovatno, ali nezam zosto ne cita nisto
  22. Avid
    Avid
    4,617
    6,971
    21 Јануари 2009
    Иди у security и изгаси safe boot а после у boot уклучи csm ако не е уклучено
  23. Electronic
    Electronic
    39
    28 Мај 2019
    N
    Nemozam da dojdam do instalacija posto imam crn ekran i poraka : reboot and select proper boot device or insert boot media in selected boot device and press a key
  24. Avid
    Avid
    4,617
    6,971
    21 Јануари 2009
    РАДИ СЕКЈУР БУТ БЕ РАДИ ЛЕГАСИ/СЕКЈУР
    ТРГНИ СЕ ОД ТОА ADVANCED МЕНИТО ОД КОЕ ПУШТИ 2 СКРИНШОТА И ЧИТАЈ ГО МОЈОТ ПРЕТХОДЕН ПОСТ
    На Daniel86 и farkizz им се допаѓа ова.
  25. Electronic
    Electronic
    39
    28 Мај 2019
    Se e napraveno kako treba isto e
    Прикачени датотеки:
  1. ChuleTheJudge
    1,252
  2. swan
    1,520
  3. Кристијан Про
    549
  4. MarkoZ99
    11
    1,191
  5. d.zoki
    21
    1,353
