- Ја почнал/а темата
- #1
BSOD
- 5 јуни 2008
- 709
- 46
Долго време барав/се мислев кој DSLR да го купам и конечно одлучив да се свртам во спротивна насока - спротивно од Canon,Sony, Nikon итн.
Го купив Pentax K200D и ептем сум задоволен. Потежок и поголем е од другите во негова класа односно перфектен е(за мене). Уште две работи во што се разликува се: користи AA батерии X4 и плус е "weather sealed"
* Shake Reduction compatible with any PENTAX lens ever produced
* 2.7 inch high resolution, wide-view LCD monitor
* Durable, weather and dust resistant body
* PRIME image processing engine
* Dust reduction mechanism and Dust-alert function
* TTL Phase-matching 11-point wide autofocus system (SAFOX VIII
* TTL open-aperture 16-segment metering with lens and AF information
* Manual sensitivity of 100-1600
* Electronically controlled vertical-run focal plane shutter (1/4000 to 30 sec. & bulb)
* 8 White balance settings
* 9 Shooting, 8 Scene, and 6 Picture modes
* Penta-mirror type viewfinder with 96% field of view
* 9 selectable Digital Filter playback modes
* Built-in retractable P-TTL pop-up flash, guide number approx. 13
* Supports external flash with hot shoe or wireless-sync
* Continuous shooting of 2.8fps for 4 frames (JPEG and Continuous (Hi), RAW
* Connectivity: Video (NTSC and PAL formats ), DC input, USB 2.0 (HI-SPEED)
* Uses SD memory card (SDHC compatible)
* Powered by 4 AA (lithium, alkaline, and rechargeable Ni-MH) batteries and optional AC adapter
* Weight with batteries and SD card is 690g (24.3oz.)
* Software CD includes the PENTAX PHOTO Laboratory 3 and PENTAX PHOTO Browser 3
Сега уште да научам да го користам
) и да сликам
* 10.2-megapixel CCD sensorThe K200D boasts an extremely reliable dust-proof, water-resistant construction, with special seals applied to 60 different parts of the camera body, including the shutter release button and switches/levers/dials. This dependable body makes it possible to use the K200D in the rain or dusty locations without worries.
